loader attachment ?
turck
m5140, JD2020, ford 850, farmal 240
Apr 20, 2013
56
carthage, ny usa
I am wondering if a skid steer pallet fork attachment will connect to my Kubota m5140 loader. The skid steer the forks were used on a bobcat. The couplers look similar in the pictures on them, has anyone tried hooking up to one.
Tooljunkie
May 13, 2014
4,150
34
Check the specs on your loader, ssqua
Or skid steer quick attatch is what you are looking for.
If they appear similar, likely they are.
9,807
One thing to note: SSQA attachments can sometimes be too heavy for a tractor loader to use or use efficiently.
So size your attachments accordingly.
I have a set of SSQA forks that are almost too much for my L but they work great on my Bobcat!
L.C. Gray
L3400, RTV500
May 14, 2016
105
Stephenville, Texas
There are light duty SSQA pallet forks made from tubing that are stronger than the machines can handle in lift capacity without the added weight and cost of a set made of solid steel.
I got a set from Titan brand new shipped to my door for under $300
rjcorazza
Mar 9, 2016
778
25
Hyattstown, MD
I also ended up with light duty forks for my L4060. 2000lbs is light duty for a skid steer, but slightly exceeds the capacity of my fel. SSQA attachments for fels is an evolving market, so I expect to see more options being developed. I believe even the new (2017) bx series tractors are coming with standard ssqa on the FEL.
