I have a2002 L301. I've noticed that the left rear wheel will stop pulling at low RPM. The right wheel continues to pull and will drag the left. Could this be a clutch problem or a differential problem? Thanks for any help you can provide.
Not gonna be a clutch problem.....sounds like the axle to the left side has a broken spline or chipped teeth where is meet the diffy.I have a2002 L301. I've noticed that the left rear wheel will stop pulling at low RPM. The right wheel continues to pull and will drag the left. Could this be a clutch problem or a differential problem? Thanks for any help you can provide.
