Left rear whell stops turning
forrestsw1
L3010
Aug 25, 2015
Fyffe, AL
I have a2002 L301. I've noticed that the left rear wheel will stop pulling at low RPM. The right wheel continues to pull and will drag the left. Could this be a clutch problem or a differential problem? Thanks for any help you can provide.
3,082
Not gonna be a clutch problem.....sounds like the axle to the left side has a broken spline or chipped teeth where is meet the diffy.
Jack up rear - spin right side - left will not move at all ?
and it is gonna require some digging in that left side I am afraid. WSM will help big time on this!
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,979
Near Lancaster, PA, USA
Could also be everything is OK and you need to depress the differential lock when the traction conditions are bad?
jnschnit
B2601, BH70 BH, LA435 FL, RCK60-32 MMM, BX2763 Blade, ZD1011
May 10, 2013
139
46
newark valley new york
Have you checked the air pressure of the slipping wheel? Had similar problem and found the the tire was slipping on the rim. Cheap fix if it turns out to be the problem.
ipz2222
L235, bx2670
May 30, 2009
1,927
34
38
chickamauga ga usa
If axle is broke or splines stripped, tractor will not pull itself unless in 4wd or diff lock is depressed. Does this only happen in a load, ie, fel digging in dirt,, pulling a mower, etc???
