LandPride SGC05 grapple problem
millsan1
BX25D, SGC05, 4' Box Blade, 6' rake, 6' blade, Titan BX42 Chipper
First, I love my grapple. It is really a useful implement.
I have used it for picking up leaves, making brush piles, grabbing rocks, etc.
That being said, mine failed yesterday, in an impressive fashion.
The welds on the upper brackets, where the rams attach, broke.
I looked at the welds, and the brackets are only welded on one side. That is really odd, and a poor choice by LP, IMHO. The brackets are a single piece of 1/4" steel, acting as a standoff from the cross member. These brackets take all the stress. Seems silly to not spend the extra buck or two to weld both sides of the 1/4" piece.
I have to bring it to my dealer to have them "start the process" with LP.
I am hopeful this will be easy and not a painful drawn out thing.
I could repair the weld, but this is a brand new piece of equipment (45 days old or so) and the damage is from poor design, so I don't feel like I should do the repair.
The point of this post is to let people know about this flaw. I suggest, if you buy an SGC05, that you weld, or have someone weld, the unwelded side of the bracket before using the tool.
Left Bracket
Left Bracket front
Right Bracket
Right Bracket
CountryBumkin
Sep 27, 2015
568
Central FL
Wow - I never noticed the welds are only on one side. I'm going to check my welds when I get home.
It looks you may have had some old cracks there too - based on the rust in the crack. Had you noticed that earlier, and rewelded then, maybe you could possibly have prevented the total failure.
CountryBumkin
Sep 27, 2015
568
Central FL
I took a close at my SG05 Grapple, and it's like yours - I have a full length weld on one side of each bar/bracket and a smaller 3/4" to 1" weld on the other side (one at top and one at bottom). It would have been nice to see full welds on both sides.
millsan1
Yeah, it seems like a foolish thing to do, on the manufacturers part. It would cost very little to do the full weld.
Once mine is fixed or replaced, I will have a buddy do a full weld for me, as my little welder can't pull this off.
7,264
Skeets, how do you type a one word response and get it to post?
I typed in "A trap" as an answer to another post, and forum told me the response too short.
rtgt
B3200
Jul 30, 2015
96
Kentucky
Yikes! :eek:
That doesn't look good.
Hopefully Landpride will get you fixed up and running again.
Kennyd4110
Vendor Member
Sep 7, 2013
1,431
763
Westminster, MD
www.boltonhooks.com
I don't think that would have helped much, the single weld held just fine, the tube is to thin and ripped next to the weld causing the failure. The bracket is poorly designed, it should have never been just stuck to the top of that tube-even if the tube was thicker IMHO.
8,935
I think it's a 10 character minimum counting spaces. : eek : or :eek: counts as 5 :D
millsan1
Well, here we are, two weeks later.
LP is sending a new frame to dealer to put everything together.
No ETA.
I am glad they are fixing it, but I need that implement. Waiting is the hardest part.
CountryBumkin
Sep 27, 2015
568
Central FL
Post back if the new frame is fully welded - maybe LP learned something and improves their manufacturing process.
rtgt
B3200
Jul 30, 2015
96
Kentucky
No ETA.
Sorry to hear about the problem, but glad to hear that Landpride is standing behind the repair.
millsan1
Good News/Bad News
Good News:
New grapple frame supplied
Dealer installed it the same day it came in, and called me before noon to come pick up!
Bad news:
Same shitty welding. Will have to fix.
Thanks
RWey56
BX23S
Feb 8, 2018
111
Stanchfield, MN
I'm planning on picking one of these up in the next week or so, and given this thread and others re the same subject, before I even hook it up I'm going to look over the whole thing and likely fire up my Miller and add whatever extra welds are required.
Because this thread is two years old, it will be interesting to see if LP has addressed the issue.
bearbait
Dec 9, 2011
4,159
912
New Glasgow Canada
Please post your results, thanks.
RWey56
BX23S
Feb 8, 2018
111
Stanchfield, MN
Will do.
If the implement is the same as in the past, the pictures suggest there's a lot of places that could benefit from some small patch reinforcements and simple corner gussets as well. Who cares if it adds 10 or 15 lbs ?
