Land plane build
Sawburner
L2501, Gravely 526
Dec 18, 2022
109
343
NY
IMG_6919.jpeg IMG_6920.jpeg Building a land plane to maintain my gravel drive way. Using steel I have on hand, I am having a couple plates made where I used to work. They can punch the holes in better than I can cut them out with the torch, too big to drill on my drill press.
Reactions: 9 users
5,551
Keep the pictures coming, I ,for one , enjoy seeing what a guy can do with scrap(y) and a welder !
11,035
Less angle on the blades, more distance between the blades.
5,312
Looking good sir!
I am also paying attention for my future “Land plane build"
Just gotta finish the 234,789 other projects I have started ;) :ROFLMAO:
Where did you get that blade from?
Sawburner
L2501, Gravely 526
Dec 18, 2022
109
343
NY
I got the blade at auctions a few years ago and was going to put in on a bucket on my 8N Ford, never did, sold it to buy the Kubota. Should work fine for a cutting edge.
7,648
Looking good sir!
Might go to your local county road and bridge dept. Probably have a dumpster weighted down by them.
pigdoc
G1800S L2500
Aug 19, 2022
403
349
SE Pennsylvania
To Wolfman's point, do some surfing on YouTube to find videos of one of these in use. I think it's common for adjacent blades to have 'opposite' angles. One blade throws material to the right, next blade throws it back to the left. Will be difficult to control if all of the side thrust is in one direction. [Thinking of how much I have to countersteer when I'm pulling a big angle blade full of snow.]
Also, swing by your local township maintenance yard. They might have used grader blades that they'll give you for scrap price (currently very low). When I was a kid, Dad got hold of about 50 of these, and we set them in concrete as fence posts for the feedlot. Was pretty easy to bolt cattle panels to them. They're tempered, you can't cut them with a saw. All of the county roads were gravel, so there was a surplus of these.
-Paul
11,035
-Paul
The blades can run the same direction, they design them both ways.
It really doesn't pull to the side.
And suprisingly the material does not all end up on one side either.
Sawburner
L2501, Gravely 526
Dec 18, 2022
109
343
NY
Finished, works good, my driveway is in good shape and this will help me keep it that way. I just need to keep the crown and the water will run off and not down the driveway.
