LA535 Suppot Leg Breaking Latch Bolt
CD824
LX2610, FEL, Bad Boy Maverick HD, LP LR1672 Rake, Woods Box Blade, KK Blade
Aug 4, 2022
Central Illinois
Hello,
I have a new LX2610 with a LA535 Loader. One thing that has happened a few times now, is that during normal loader and bucket function, the mechanisms that allow the legs to drop down somehow engage and shear off the bolt that holds the leg up. It's the most baffeling thing. I have replace the bolt 3 times now. I have attached a picture to show. Yes, I know it is under warranty, but I was wondering if anyone has any insight as to why this is happening? 16850510596247437035714787583536.jpg
GrizBota
Apr 26, 2023
1,147
733
Oregon
Interesting. I don’t know why that’s happening, but I know that just yesterday someone had a very similar post, picture and question, see the link below.
More busted swift tach loader pins
jkrubi12
B2601/LA435/QA54"/BH70/B8160box/BB1254/PFL1242/SGC0554/BX2812APlow/WC-68 Chipper
Sep 24, 2012
403
302
right coast
Although I have not experienced this issue on my B2601 with the LA435 swift tach system, I'm of the opinion that the damaging of the loader stand retention pins is related to bucket dumping and the position of the loader stand release lever (left side of loader boom when seated on tractor).
In order to activate the loader stand legs for loader removal, a combination of fully dumping the bucket and releasing the loader stand retention pin(s) lever must occur. In a perfect scenario, once the bucket is in the full dump position and the pin lever is released, the stand legs should be free to fall down into the 'loader off' position; this process likely involves the crescent-shaped shiny metal (unpainted) freely-swinging devices located at the bucket end of the loader boom arms.
I suspect that bent pins is a result of a full dumping of the bucket, with some unintended involvement of the crescent-shaped device(s), which somehow causes the stand arms to partially fall or disengage from the retention pins (likely one side is involved with the other side still retained). Upon curling back the bucket the pin is bent as a result of the detached leg not dropping because the other side is still attached.
If this occurs without any movement of the retention pin detachment lever then I imagine that the solution (once a new unbent retaining pin is installed) would be to inspect both the crescent-shaped device and the stand leg itself and determine in one or both need some sort of adjustment to prevent unintended disconnection.
I've never personally removed my loader (I have 'dropped' the stand legs to confirm that they are functioning properly) but based on my limited knowledge of the system this is my advice on diagnosing the problem. Good luck, hope this is helpful! :)
BX23-S,57 A-C D-14,
6,310
One possible reason they fail...
The 'loader leg' is heavy and supported at the end of the 'pin'. Unless the leg is 'solidly' held firm against the pin,it'll eventually 'stress' the pin at the weakest point, where the threads are.
Wondering HOW the paint on the top of the 'opening' got chipped off ?
Maybe use a bungee cord to help secure the leg up tight against the frame, to prevent movement ?
CD824
Aug 4, 2022
Central Illinois
Hello,
I have a new LX2610 with a LA535 Loader. One thing that has happened a few times now, is that during normal loader and bucket function, the mechanisms that allow the legs to drop down somehow engage and shear off the bolt that holds the leg up. It's the most baffeling thing. I have replace the bolt 3 times now. I have attached a picture to show. Yes, I know it is under warranty, but I was wondering if anyone has any insight as to why this is happening? View attachment 103408
Hello,
I've had this happen on my LX2610/LA535 several times and it's very frustrating. I even wrapped a bunji around it to hold the leg up. Did you ever find the cause or solution?
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,979
Near Lancaster, PA, USA
I'm pretty sure it's not the case, but the number of threads showing on that bolt make it appear that the bolt was loose.
The picture in the thread GrizBota referenced has similar marks out near the end of the pin. Wonder if the stand should hang closer to the plated lever to reduce the leverage the stand has on it.
davep
LX2610SU, RCR1860, BB1260, QH10, CID HBHS, CID CTFF, WR Long RBG2
Jul 20, 2021
54
19
I didn’t realize this was a common occurrence. I have replaced these bolts at least three times myself on my LA535. I took it back to the dealer to get fixed. Nothing works. I emailed Kubota support asking them if they can replace it with a non swift tach loader.
I have about 350 hours on the machine, and one time the bolt broke when I was doing work with it and the leg fell down and bent a bunch of stuff. This swift tach system is a nightmare.
John T
2017 BX23S 385XP Miller211 1952 Panhead Orange Ludwig 4 piece
May 5, 2017
1,336
859
under a rock
That whole system is a poorly thought out / over engineered failure.
Completely unnecessary in my opinion,
I removed all that garbage and installed a simple hairpin to hold up the support stand.
Same thing the older BX25 uses.
pull the pin... It drops. EZ-PZ
Very easy to use/less weight and less BS.
davep
Jul 20, 2021
54
19
This was the way. I didn't realize that the regular leg stands were also on the loader. So it had these swift tach leg stands in addition to the regular ones. I took off the swift tach ones during lunch today, and I've never been happier.
