La525 on my l3301 uneven lift
Richc
L3301 hst 2015, fel la 525, bh77, 42in forks, 66in box blade, post hole digger,
Jul 26, 2019
New hudson michigan
Once upon a time I was working clearing brush and a branch pushed up the right quick disconnect handle thus allowing the bucket to dangle off the left side, since then the right side always lags just a bit when lifting. Is this a torque issue on the fel frame or is there an adjustment to dial both sides in so they work in together. Any one else have this issue or know of a fix?
The left side lifts approx one half inch before the right lifts
philip53
L3301 with 525 FEL
Jul 26, 2019
Jonesboro, Louisiana
Rich there is a good chance one of your quick attach mounting 'plates' has been twisted during your incident and it takes about 1/2" of take-up play to get them to 'sync up' again & lock securely. Since the hydraulics will move the cylinder with the easiest resistance first, you will see that side move first until the FEL frame takes over and the entire FEL unit moves as one.
5,373
Yep the SSQA is out of sync.
Search the forum for ways to line it back up. ;)
Jblac197
L3800, bush hog, tiller snowblower
Aug 21, 2018
73
Hibbing
A half inch is really nothing to worry about..
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Richc
Jul 26, 2019
New hudson michigan
Thanks for the responses, yes I actually took off my quick attach from the tractor and laid it down, that’s where I could really see the twist. Although after viewing others with similar issues I realized and as you mentioned half inch is nothing in the big picture. Now at least I know where the uneven issue lies. I’m a bit of a perfectionist so when I would see one side move slightly before the other I became curious. Thanks again.
