T tehans New member Aug 28, 2019 20 0 1 Orient Aug 29, 2019 #1 I just got a 2400 with a LA351, the stick is sloppy, what parts normally need replaced to fix this? Also does this have a float function?
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 34,727 9,984 113 Sandpoint, ID Aug 29, 2019 #2 tehans said: I just got a 2400 with a LA351, the stick is sloppy, what parts normally need replaced to fix this? Also does this have a float function? Click to expand... Same website I gave you before will give you the answers. It's kind of hard for us to see your worn parts from our locations, , Only you can tell what parts are worn and need replaced.
T tehans New member Aug 28, 2019 20 0 1 Orient Sep 3, 2019 #3 Here is a video, does this seem too sloppy? I have never had one of these before https://photos.app.goo.gl/tu248YhRnkwFKucP6
kubotasam Well-known member Equipment B2410, B7100dt, B7500,Woods BH750,Landpride 2660RFM, Tiller, B2781 Snowblower Apr 26, 2010 1,211 135 63 Alfred Maine Sep 4, 2019 #4 I would say you definitely have some worn parts. Take it apart, look for out of round holes or pins and replace them. The bottom of the assembly has a replaceable bushing.
