I think that this is a not unusual problem. The loader was working fine and then in the colder weather it would not raise until the tractor had run for a bit and warmed up. Then it worked fine. Now it has stopped working. Only the raise is not working. All other functions work. Bucket curl and down. I tried switching the two lines on the control for the raise/lower functions and it worked. When I inputted to raise the bucket the bucket went down and would lift the front of the tractor. When I inputted to lower the bucket the bucket went up as in normal operation. When I switched the two lines back (quick connectors) I was back to square 1. All other functions worked but the raise did not. Any suggestions greatfully appreciated. The tractor is a B2150 with LA350 FEL. Thanks.
