csdifani
Kubota B7510, LA272-1, FL1020, 4672A and there's too much "other" to list...
Folks:
We have a B7510 with a LA272-1 front loader. My wife arrived (she's the tractor operator.... and I'm the tractor fixer) at the shop complaining of the front bucket lowering very slowly. My wife has a small organic orchard (352 trees...), and she loves her Kubota... and every attachment that she has for it, so when it's not working "properly", my priorities get immediately rearranged.
The problem started without any symptoms, went from perfect operations to not in a moment. I checked the hydraulic fluid level, and everything else I could think of. Everything was "right", no leaks, not a lot of "slop" in the control linkage, and the bucket circuit works perfectly (tilting up and down). The forks raise correctly, but lowering is the problem.... as in it doesn't... except when you push the control stick up thru the detent and the bucket "falls".
I found the thread from "Butch" in 2010, which is why I'm posting here. I'm hopeful that you folks have a suggestion or two on where I need to be going... workbench, lathe, mill, parts house, eBay, etc.
Her B7510 has 860 hours on it, and she's the "second" owner. All the preventive maintenance gets done, and it's got it's own stall in the barn. One thing I don't know (from the thread info) is which valve body we have. I didn't find a serial number on the valve body either, but I wasn't looking real hard at the time (serial# for the LA272-1 is 53287)
The valve body looks good; no leaks, no apparent damage or problems. And the same with the hydraulic hoses and cylinders. I did change the hydraulic fluid and filter last winter (when I also serviced her 4672A backhoe attachment), and didn't see any noticeable corrosion, or contamination in the old fluid.
But there is something obviously wrong... and most likely it's in the valve body.
Thanks for your time for reading this, and for your expertise in telling me the (probably/hopefully) simple fix!
Chris Difani
Chris Difani
