la1154 loader issue
James cuzzen
M6060 la11
Dec 29, 2023
9
Need to know what if any hydraulics you have or have added to rear of the tractor.
How many remotes, did you add any remotes, top and tilt........
The rear is fed by a power beyond circuit from the loader valve. If a rear remote is not in the middle position but is calling for pressure/fluid it will affect the loader.
Have you temporarily tried swapping bucket and loader arm hoses to see if the problem moves. Quick connects not fully seated or failing internally will produce weird actions.
Don't try messing with the loader vale by removing spools. They are installed with clearances you cannot even measure they are outside the typical clearances for valves and spark plugs and rely on the tight clearances to prevent leakage.
History of your machine is a help to members offering you advice. Buy new or used, problem developed suddenly or gradually........
Dave
Goodmorning gentleman here is the things that was asked about on my la1154 loader its on a m6060 2015 modelit was when they were changing over to the regen looked at one with no regen but by the time I got my cash together it was gone, so regen I went . So I bought this m6060 with loader la1154 new in 2015 with with box scrap and bush hog now the box scrap is normal size but the bush hog is some what large and heavy duty made for the job my last tractor long 680 that bush hog took a beating ,
Now the m6060 would not lift this bush hog up high enough to get it to a good clearance when not in use I took it back and was going to see if there was a way of getting it higher up when not in use a man that worked there asked me if he could help me and told him what my problem was he sad he could help he went to the back of the tractor and put his hand under passenge side I watched what he did he turned one of those two set screws I think they go to the up and down on the 3 point hitch he sad raise it so I did it went up higher I guess I told him I could still hear the pump running he sad lower it down a little and it will stop now this sounds a little bit off to me as I've looked back on it I think he was full of it I've not messed with it its still like he set it but I have replaced both joy stick cables one hose it was going to the bucket my son blue it out not got the hole dill out of that yet I have switched curl and dump lines then it dumped in both curl and dunp and did it fast but would not curl up so I switched them back took of the lines at the quick coupler to make sure they were getting fluid though them and they are I can take the cables lose from the spools at the valve body and pull or push them and ever thing works fine but the dump it's still the same way and by the way the floating bucket dose not work , but when I'm adjusting the cable last week it starts working somefirst time in a while.
Now though all this I was layer up for a while with a knee replacementand I'm still waiting on a shoulder replacement I saw this one day when I had to move my tractor over to my other building so I could park were it was . Now as far as the valve body I've been out of work for a while and got a while to go so I took out the spool for the curl and dump the white ring was broke so I ordered a new one and the black o ring to I put them in that's been around two years ago I've had this problem I guess 4 or 5 years and I've been looking and reading a lot about this I think I put the white ring and the black o ring in in the wrong order this has been a rough and long time I sure hope you gentleman can help thank you so much
9,696
Please restate what your issues/ Questions in simple terms and break it up with an enter and space between the questions.
James cuzzen
M6060 la11
Dec 29, 2023
9
I have a m6060 with a la1154 loader on it. It will not dump, unless you hit the sweet spot, and the slightest movement will make it stop. I have to bump it over to the curl, and then go back to the dump. Sometimes it will take anywhere from 5-10 times of bumping it to get it to dump.
I have switched the hydraulic lines for the curl and dump at the quick couplers, and they both dumped. I switched them back to their original position and took the hydraulic lines off at the quick coupler to make sure they had flow and were connected back correctly.
Any help would be greatly appreciated. Thanks in advance.
James cuzzen
M6060 la11
Dec 29, 2023
9
I bought the tractor new in 2015 and the issue with the bucket started all of a sudden. I will check the rear remote and make sure it is in the middle position. I have not added any hydraulics, and all the hydraulics on it are original.
James cuzzen
M6060 la11
Dec 29, 2023
9
All the hydraulics on it are original. No remotes have been added. I will check the rear remote and make sure it's in the middle position.
I bought the tractor new in 2015. The dump issue started after about 2 years, and it was all of a sudden. Thank you for any advice or help.
6,016
That loader valve has fast dump so you cant just switch the lines on the bucket. If they are hooked up backwards it wont curl and will actually dump when joystick is moved to curl.
James cuzzen
M6060 la11
Dec 29, 2023
9
Yes that was my understanding , but that would let me know that it will still dump and sometimes the joy stick will get to far out and I have to readjust it and the floating bucket will work
