LA 364 loader question?
mike paulson
232
27
ulster, NY
I was reinstalling my loader onto my B2620 today and could not get the red marked hydro line to connect, I took a phillips head screwdriver and poked the button inside the fitting to relieve pressure on the tractor side fitting and still couldn't get the line to connect. Then I tried to relieve pressure on the fitting on the loader line and couldn't press in the little button. So I took a 1/2in allen socket and put it against the button on the loader line and tapped it with a hammer and it shot hydro fluid out and then reconnecting the line was a breeze. Has anyone else out there encountered this and what was your solution?
9,723
Solution one: Make sure you revive all pressure before disconnecting the lines.
Solution two: Change the couplers out for flat face couplers, they let you connect with pressure on the line.
BAP
Dec 31, 2012
3,069
1,193
Flat face couplers also leak less than the ones the pin style that come with the tractor.
Denm
B2620, LA 364, BX2360A blade, Lp BB1248, quick hitch, G1700 w/48" deck
Dec 2, 2010
30
Nova Scotia
Had same problem with mine. Made sure engine was off and relieved pressure before disconnecting the lines. The only thing I can think of is maybe the bucket moved after sitting awhile and increased pressure in the line, not sure:)
