L5240 remote leaking
tractorroadie
BX2200, L5240,
Oct 25, 2025
Nashvillle, TN
Hello all. I’ve recently had our local dealer install a rear remote on my L5240. I hooked up a round baler to test the new remotes. At first it seemed fine as the rear gate was lifted easily. Upon closing the gate, it was incredible slow and started leaking hydraulic fluid out of the remote valve block. Took it back to the dealer and they found no problems. Brought it home, same thing, but I took a video and sent it to the dealer. They’ve responded wanting to know the model and brand of the baler and then went quiet. I’ve attached the picture to this post. While I know you should not dead head hydraulics and I don’t on purpose, but you can make the leak happen by dead heading the remote in either direction.
i would assume a pressure relief valve would release before it leaks. Any ideas? Thanks.
7,027
That leak should be obvious to the dealer. My first guess would be one or more orings out of place and/or debris trapped between the valve sections. In other words faulty workmanship by the dealer.
