L5030GST WILL NOT GO OVER 7mph
DALEATHERMAN
L5030GST
Oct 13, 2018
9
Salisbury,Md
Owned L5030GST SINCE 2004. This last year i was unable to go over 7mph.
C/O HYDRAULIC FLUID AND FILTER REFILLED WITH KUBOTA UDT SUPER, PROBLEM STILL EXISTS. CHECKED CLUTCH FREE PLAY ADJUSTED WITH NO CHANGE. DONT KNOW WHAT TO CHECK NEXT. LOOKING FOR SOME ADVICE.
THANKS.DA
4,091
Just a dumb question,, did ya check if she is in low range?
greeno
B2710 w/LA402 FEL, BL4690 hoe, RB1560, GS1560, Haban 5' sickle bar, 5' JD RC
Jul 14, 2018
187
Big Lake MN
Not a dumb question...maybe his range selector is broke.
DALEATHERMAN
L5030GST
Oct 13, 2018
9
Salisbury,Md
There are twelve forward speeds. No matter which speed your in it won’t go over 7mph. Shifting with the clutch or using GST result.
NoJacketRequired
May 25, 2016
431
71
Ottawa, Ontario
I was caught out recently when my father engaged the parking brake. Tractor didn't go fast at all, then started to smell funny... DOH!!!!!!
8,805
GST's don't have a range selector, it's all done in the transmission via hydraulics.
Do you feel it change gears?
All gears?
shootem604
Apr 23, 2018
874
British Columbia
I know of someone else who had this problem, where top speed forward seemed to be limited, but reverse still worked normally. Don't know what was wrong - it was sent to the dealership to resolve. Does your tractor still perform properly in the reverse gears?
Firefighterontheside
1997 Kubota L4200
May 24, 2018
120
DeSoto Mo USA
My 1997 gst switches from high to low between 4 and 5. I’m wondering if yours has low, medium and high. If so, low and medium are working, but Hugh is not. According to tractor data.com speed 8 should be 7.5 mph.
200mph
Mar 3, 2017
1,228
61
PA
According to my WSM Speed 8 is 7.8 KMPH not MPH. 7.8 km/h equates to 4.8 m/h.
GST Gear......... Speed (14.9-26 tires)
..8.................... 4.8 MPH
..9.................... 5.7
.10................... 6.8
.11.................. 10.9
.12.................. 16.4
Is it possible your air cleaner is restricted or poor fuel delivery decreasing HP?
200mph
Mar 3, 2017
1,228
61
PA
I don't have a GST and have never used one, but I did read the WSM and the brief description of GST operation.
There appears to be two speed control levers that are used together to achieve the 12 forward speeds.
There is one lever on the left side near your hip which is the Main Shift Lever and another on the left hand side of the steering column (Shuttle Lever). The intellipanel can display the speed and which gear is selected.
There is a section about the various sensors and solenoids used to control operation.
Strongly suggest you consider purchasing a WSM and perhaps the operation manual.
1997 Kubota L4200
May 24, 2018
120
DeSoto Mo USA
I have GST, but it has 8 forward and 8 reverse, a bit different than the 5030 in question. On mine the shifter at my left hip goes straight for 1-4 and then it goes sideways about an inch and then down for 5-8. It automatically changes from low to high in the transition from 4-5. I’m assuming the 5030 is similar.
8,805
On your L4200 it's a 4 speed transmission with low and high.
8,805
Anyone out there have any idea as to what might be going on?
I am thinking that this problem was a more common occurance
Does the motor rev to full rpms and hold them?
It's sounding like you have a burned out or stripped splines on the mechanical clutch.
DALEATHERMAN
L5030GST
Oct 13, 2018
9
Salisbury,Md
I will take another look at air filter but engine seems to be running fine.
Will double check reverse gears,don***8217;t think I have this problem in reverse.
Engine revs up and holds constant rpm,when operating back hoe she performs fine at a constant 2200 rpm.
DALEATHERMAN
L5030GST
Oct 13, 2018
9
Salisbury,Md
Is there a self test that can be performed to determine if the splines on the clutch are stripped or not?
Shouldn***8217;t I have smelled something burning or heard unusual noise?
