L5030
gpreuss
Oct 9, 2011
1,166
Spokane, WA
I'm having trouble understanding what you are doing. Disconnect the implement PTO shaft and verify that the pto works OK with no load. If this is a brush hog, it sounds like one of the blades has swung around and is pointing toward the center. Most likely you have an implement problem.
8,671
Bad PTO U-Joints?
Mis-aligned U-joints?
Stuck, bent or broken blades?
PTO shaft too long and binding?
Stubbyie
879
Midcontinent
Try greasing well the two U-joints on the PTO drive shaft.
This assumes you've tested the assembly by disconnecting from the implement and slowly turning the PTO shaft--you can turn fast (540-rpm per your dashboard readout) but be certain the shaft is restrained from flopping around and getting away.
Confirm also you are not over-speeding the PTO by rev'ing the engine too fast.
Then lift the implement and check for bent broken chipped blades and / or foreign material wrapped around the blades / stump jumper / blade mounting bar.
If you replace one, plan to replace both blades for a matched set. Confirm also you have the correct blade for your model and direction of rotation. Check mounting bolts and tighten; confirm mounting bolt keyway is intact.
Don't crawl under the raised implement or attempt to work on it unless it is independently supported by chains and / or jack stands with the 3-point lift control in the full 'down' position.
Check also for gearbox on implement correctly lubricated with quality gear oil.
Please post back your experiences so we may all learn
