L4701 Engine model and series
Bark
L4701/FM2560LA765/BB2560Pittsburgh disk Titan P forks
Feb 18, 2020
202
55
North CA
Decided to jot down my engine S# on my L4701 just in case I ever needed it. Couldn't find it. Finally found something that might be it but went to the Kubota web site to make sure I was looking at the right spot and now have a headache. The number I found is 5 characters and their site says it should be 7.
I guess I have a model V2403-CR-E4 engine. I don't know what any of the numbers or letters mean.
1. Do I have a Series 05 engine?
2. Am I really getting stupider as I get older or does it just seem that way?
Justasquid
L4240HSTC
Nov 2, 2020
96
45
you aren’t by chance looking at the EPA label are you?
depending on your series. the Tag could be located below the exhaust manifold, below the intake manifold or on the injection pump
whitetiger
Nov 20, 2011
3,727
2,148
Kansas City, KS
Here is the serial number location for an L4701.
Bark
Feb 18, 2020
202
55
North CA
Any thoughts on what "series" number my engine is?
Thanks. The wiring harness totally blocks it. Without that illustration I would not have found it.
Thanks. This is what I was looking at. The Kubota web page insinuated that this was it. Left side of engine stamped on engine block under exhaust manifold.
5,515
2,227
V2403-CR-E4
V=4 cylinders (first letter of the german number spelled out)
24=approximate displacement, in this case 2.4L (approx)
03=series. 03 series.
CR=common rail injection.
E4 has to do with emissions. IIRC Tier 4 in this case-but I'd have to look back in documentation and I'm too lazy to do it right now.
Bark
Feb 18, 2020
202
55
North CA
V2403-CR-E4
LoL. Wonder why they used the German word Vier for 4. Left over from their alliance during WWII?
Thanks for the info guys.
Bark
Feb 18, 2020
202
55
North CA
Main reason I wanted the engine serial number is in case it ever gets stolen. Other reason is so I can date the engine incase parts are slightly different from year to year (or sometimes month to month).
So much paint on the numbers I cant read a few of them. Spoke with the parts guy at the dealer I bought it from. Figured I would get the number from him so I could verify my best guesses. He has the serial numbers for just about everything on my tractor except for the engine serial number.
Guess if it ever becomes important I will have to try and scrape the paint off but it has become a challenge. Somebody somewhere must have information on what engine number was paired with my vin number.
5,515
2,227
possibly original designer was german? Dunno. Or maybe they wanted to be funny. Or maybe it's just ironic. E=1 cyl. Z=two cylinder. D=three cylinder. V=4 cylinder. F=five and S=six. The S engines are the only ones I can't recall working on, only an M4000 that I put an air filter in--only one I can think of.
Gas engines are WG's. Who knows what that means. Some of the ZT mowers use KZG770 engines which Kubota didn't originally design (Subaru/Fuji/Robin did)
if ya'll look at kubota engine's website, you'll see a lot of gas burners. There's no reason that some of those can't be put in a tractor, makes the same power and in some cases MORE torque than the current diesel does. Fuel usage is a little higher though, not a big concern for hobby farmers with small properties.
Bark
Feb 18, 2020
202
55
North CA
Good info, Thanks.
I scraped some of the paint off and got my engine serial number. I already had a free can of grey paint from scraping the paint off the HST to get the S# for the dealer during that recall. He was so happy for not having to come out and do it and even happier that mine wasn't part of the recall that he also threw in a couple of quarts of hyd oil.
