L4701 clutch issues
Wildhorn
L4701
May 16, 2026
Jay fl
Parked tractor on Thursday. Went to use it on Saturday. Mashed clutch, fired her off and startied putting shuttle shift into gear. Tractor acted like no clutch engagement. Clutch worked fine on Thursday. Inherited tractor. When I got it, it had 385 hours. Now has 1177. It has never fully shifted into the low side of the shift lever. But has always stayed engaged. What would cause the clutch to stop working sitting for 2 days? 2017 yr model. L4701
6,866
Going from working fine when parked to not working at all 2 days later, I’d start with a thorough inspection of any and all linkages involved.
11,237
Something in the clutch linkage or mechanism.
If it's not engaging or moving then most likely the clutch disk , less likely the pressure plate.
If the pedal is soft then something in the linkage is bound up or broken.
Trash Panda
L2501
Feb 18, 2022
287
270
Wyoming
What broke?
Clutch parts?
In all seriousness, start tracing the clutch linkage, and look to see if everything is in order. We aren’t gonna be able to diagnose what you have going on with the information provided.
3,148
Your description is a bit confusing since many people use “clutch engagement” when the really mean “clutch disengagement”. You also don’t state your tractor model completely so we have to assume that it is a mechanical gear transmission not HST and that it is the drive clutch that is the problem. I believe it has a separate PTO clutch. And there doesn’t appear to be a specific model that states “shuttle shift”. So most people seem to be reluctant to post anything that specific for your problem.
So I am assuming that when you release the tractor clutch there is no movement of the tractor. That is clutch engaged with the flywheel.
But you can engage the gear you want to with the clutch pedal pressed down. That is the clutch disengaged from the flywheel.
So have you examined all the linkage between the pedal and the clutch pedal and the clutch lever that enters the transmission case? Does the clutch lever get moved when the pedal is pressed and released? If so, then you may need to remove the shifter or some cover plate to see if the clutch release fork is moving. (I don’t see any easy way to see int the clutch area but there may be some cover to remove.).
ASSUMPTIONS ARE BEING CHANGED 180 DEGREES!
Now I am assuming that you really mean you can’t get the tractor to shift into a gear when it is running. That would indicate that the clutch plate may be stuck to the flywheel and not being disengaged by the clutch pedal being pushed down. Two days seems quite quick to be stuck but you are in Florida where corrosion could occur rather rapidly.
So you may need to put the tractor in gear when not running. Hopefully it is sitting out in an open area so you can crank the engine and not run into something. You need to get the tractor to be under some load (pushing against a stout tree or pulling a ground engagement implement) with the clutch pedal tied in the fully depressed position. It would hopefully be und enough shearing load to break loose.
But it could also be that the clutch plate or pressure plate has “broken“ and you need to split the tractor and repair/replace whatever is “broken“
You could also post a more descriptive description of your tractor and the specific problems that you are experiencing and get more specific, experienced solutions.
Wildhorn
L4701
May 16, 2026
Jay fl
We are talking about a clutch. And I mentioned shuttle shift. I said the tractor is a L 4701. Even stated year model 2017. So I don’t know how to b more descriptive than that. I’ve never heard of a HST having a manual clutch. Or shuttle shift. I have split this tractor before because of a broken shuttle shift fork. I just couldn’t understand how a perfectly working clutch could seize to the flywheel in 2 days. Yes I’m gonna have to split it again and put a new clutch in it. Then shortly after, somebody else can own this pos. Why would any tractor manufacturer make an economy tractor is beyond me. This thing only has 1175 hrs on it. A shift fork should not have already broken, rear wheel is splitting at the lug nuts, and a clutch is gone out. I’m 65 yrs old and started driving tractors since I was 10 yrs old. Never had one that has had this many issues. Thanks for trying to help me. First kabota I ever owned. Just hard believe it’s having this many issues with no more hours than it has.
Trash Panda
L2501
Feb 18, 2022
287
270
Wyoming
Plenty of HST tractors out there with a clutch pedal, I own one.
Other users have outlined how to possibly unstick a clutch for you, saving you from having to split the tractor if that indeed is even your issue. Could be something as simple as a linkage issue.
May wanna ask the guys over at the kabota forums what they think? There is a lot of knowledge here, but it is a KUBOTA-centric base.
Good luck.
whitetiger
Nov 20, 2011
3,778
2,183
Kansas City, KS
In your expert tractor driving experience, at how many hours should a shift fork last before it is OK for it to break?
Did it break from a defective part?
Did it fail from an aggressive operator?
Did you lock the clutch pedal down to disengage the clutch as per the operator's manual?
Any long-term expert tractor driver would know that blocking the clutch into disengagement has been instructed for over 75+ years now.
Which supplier manufactured the wheel and center?
You do torque the wheel bolts regularly as per the Maintenance Chart, don't you?
Wildhorn
L4701
May 16, 2026
Jay fl
This is my 4th tractor in my lifetime. All tractors had over 6000 hrs when I retired them. Zero broke shift forks. So in my expert opinion, the minimum should be 6000 hrs. I have never stored a tractor. Therefore I have never locked down a clutch. If I had to store a tractor, I really wouldn’t need one. I don’t think 2 days would be considered stored. I am not an aggressive tractor driver. They cost too much to b abused. Obviously the shift fork was defective. Why would a manufacturer put a defective part in it. From what I’ve read, I’m not the only one that got blessed with a defective part. You got me with the manufacturer of the wheel and center. As far as I’m concerned, it’s painted orange so figure it out. Any more questions?
3,148
There is no listing of a shuttle shift on the Kubota USA parts site. There are three listed models shown here that are ALL L4701 models but have specific trailing letters to signify 2WD (F), 4WD (DT), and HST. So that is what I was asking you to provide to help clarify what model your tractor is. Sorry that asking you a few questions is so problematic.
Wildhorn
L4701
May 16, 2026
Jay fl
It was no problem at all. I apologize if I came off that way. I was unaware of any letters after L4701.
