R retiredcop New member Equipment L4630GST Jul 18, 2015 2 0 0 Lenoir City TN Jul 18, 2015 #1 I am new to a forum, I have a front axle leak on the right side. What do I need to check? seals or bearings. thanks
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 34,498 9,746 113 Sandpoint, ID Jul 18, 2015 #2 You need to check both. I'll send you an email with a link to download the WSM (Work Shop Manual) to help with taking it apart and repair.
Bulldog Well-known member Equipment M 9000 DTC, L 3000 DT Mar 30, 2010 5,434 77 48 Rocky Face, Georgia Jul 18, 2015 #3 I would check to see if it's building up pressure in the axle case. Summer heat and hard work can cause excess pressure and make them leak.
OldMasterTech Member Equipment KX057-4, KX121-3, L4630GST, RTV1100, AT60, T1700, T1560, 555E Mar 28, 2011 30 0 6 72 Massachusetts Apr 30, 2017 #4 retiredcop said: I am new to a forum, I have a front axle leak on the right side. What do I need to check? seals or bearings. thanks Click to expand... Retiredcop, did you ever perform this repair? What was the complexity? My L4630 is leaking bad left front axle from the largest pivot joint.
R RONB83530 New member Equipment L5740 Jan 5, 2017 10 0 1 United States Jul 22, 2018 #5 Wolfman, add me to the same list only for a L5740 thanks ron b
