My tractor is two wheel drive with Ag tires and the gear transmission with the factory loader. I have 40 acres of very rough grass that I need to work over. The hogs and gophers are destroying the hay equipment and putting livestock at risk (heck I even caught 'air time' going 10~15mph when I hit a hidden hole in the pickup). The soil is real sandy so it doesn't pull too hard but traction can be a problem.
Part 1:
I have 30 acres in the back pasture so, I'm questioning whether to try to roto-tiller everything or, just disc it up. What say the more experienced around here? A roto-tiller would probably leave a better surface for the grass with one pass but, would a disc work? Would I need to come back with a drag harrow to smooth things out? Would I need to disc multiple times to chop up everything (assuming notched blades).
Part 2:
What is a good quality good value disc for my tractor? How much should I expect to pay? I'm thinking ~8 feet with large disc blades. Do the 20"/22"/24" disc blades really work that much better and justify the extra cost? What should I expect to pay (prices are all over the place even after ruling out the flimsy discs)?
Part 3:
Same for the roto-tiller. I'm thinking I would be better served with a reverse turn model. What size and how heavy duty do I need to consider? What are the good quality good value models and what should I expect to pay?
TIA,
Sid
from East Texas
Part 1:
Part 2:
Part 3:
TIA,
Sid
from East Texas
