L4330 Stalls and clicks
mdavey
L4330
Apr 23, 2014
9
Rutledge
My Kubota L4330 (about 10 years old), has recently started stalling. It makes a clicking sound just before it cuts out. The clicking and stalling can be very rapid on/off a couple of times per second, or it just completely stalls. When it completely stalls, I can turn the engine over, but it won't start .... until I hear a click again, then it starts just fine.
I changed the fuel filter and bleed the fuel lines, but it still does the same thing ... any advice on where to start?
Thanks,
m.
Tn1977
31
Waverly,Tn
My L3800 will make a clicking sound if the safety switch under the seat is triggered. It will click then start to die unless weight is put back on seat.
mdavey
L4330
Apr 23, 2014
9
Rutledge
Thanks TN ... yeah it sounds like that type of a noise, but it does it even when it's in neutral. Once it stalls, if you leave the ignition switched on, you can hear it clicking on and off intermittently, without the motor running (but ignition powered on).
rentthis
1,010
25
summerville,sc
I had something similar with one of my tractors. I don't recall the model but it was close. It was the fuel shutoff solenoid.
8,765
Fuel shut off relay or solenoid is failing, check connections on both, a bad ground on either will also cause the same problem. ;)
ctmike
L 3750 DT with loader, brush mower, rear grader blade, box scraper, rear blower,
May 10, 2013
143
Suffield, CT
Follow your foot throttle pedal linkage to the engine. The solenoid is at the end of the linkage on the side of the fuel injection pump.
8,765
It's mounted at the front of the motor pointing to the rear, and the injector pump.
mdavey
L4330
Apr 23, 2014
9
Rutledge
You guys are awesome, thanks!
I replaced the battery today (10 years old) and it might have done the trick. I still need to do a test drive yet (once it drys up here), but it ran for over 20 mins idling, without stalling ... fingers crossed.
Thanks again!
m.
