L4200 steering problem
10,195
Could be a steering control issue, but more likely a bad seal on the steering cylinder.
Does it only drift one direction or both?
PFConnolly
BX2230D, L35, L4200
May 10, 2017
Wautoma, WI, USA
Drifts in either direction but more noticable on road travel with right drift. Tractor has 2000 hrs and has been worked hard, runs great.
10,195
Take off one line to the steering cylinder, you will need to move the wheel in the opposite direction of the line you took off, if when you get to the end it keeps bleeding fluid out the open line fitting, then you will need to rebuild the steering cylinder.
