L4150 power loss
Redwing
L4150 Tractor, 900Loader
Nov 3, 2014
23
Port Saunders, NL, Canada
First try of the L4150 I am restoring having a problem with power loss. Tractor starts and runs fine then starts to loose power, if I let it idle for a while I can get power back for a short time. Motor is not running hot. Could this be a fuel issue or maybe air intake? I haven't gotten into these systems yet.
8,826
Sounds like fuel problem, Unless the air filter is plugged up.
Have you changed filters?
Redwing
Nov 3, 2014
23
Just finished replacing fuel filter and cleaning out the fuel lines, seems to be running better but need to work it tomorrow to check for sure. Thanks for the reply.
retiredlawnboy
M6800, L245DT, L245H, Gravely 816T with Cab and Wing Mower, 5665, 1960s Li
Nov 24, 2014
Danville, OH 43014
I had a similar issue with my M6800. It would idle or at close to full throttle. Turned out the fuel pump was worn out after 2900 hrs.
