L4060HSTC PTO Pressure
GBJeffOH
L4060, EA Grapple, 6' LP Brush Hog, 8' snow plow, 6' LP tiller, EA Forks, Spraye
Nov 17, 2014
307
136
Jefferson, Ohio
I want to test the pressure because sometimes the PTO takes about a minute to shut off.
I always start and stop the PTO at idle speed.
The test port threads are PT 1/8.
I am having trouble finding a test kit with that size fitting.
I have a gauge that is 0-600 PSI with 1/4 NPT.
10,744
Just go to a hardware store and get a 1/4 to 1/8 reducer.
GBJeffOH
Nov 17, 2014
307
136
Jefferson, Ohio
PT is the abbreviation of pipe thread,which is a 55 degree sealed tapered pipe thread.It belongs to WHITW thread and is used in Europe and commonwealth countries.
6,991
My 1/8 NPT will go in maybe 1/2 turn.
If I put the black plug and screw it into a female 1/8 NPT it is sloppy.
That is BSPT not NPT. Keep messing with the wrong thread type and you will have a mess on your hands.
6,991
The local hydraulic shop had the 1/8 Bspt Male To 1/8 Npt Female fitting.
When I told the hydraulic shop 1/8 BP they had no idea. It would be nice if the WSM said BSPT not PT.
Thanks for the help.
PT is a JIS designation that Kubota loves. BSPT is a British designation. Both are currently obsolete but still used by lots of manufacturrs. Here is a little cheat sheet I put together of the designations you might run into. Most hydraulic counter people will be baffled by anything other then BSPP/BSPT or G/R.
GBJeffOH
Nov 17, 2014
307
136
Jefferson, Ohio
I should have around 400 PSI. I have 250.
No 6 is where you adjust it.
My tractor does not have that.
I don't know where to adjust it.
10,744
Your looking at the adjustment for a Manual or GST, with an HST it's the bottom picture.
