L3940 Hydraulic Issues
drubens
L3940D
Jun 22, 2018
Ramona, CA
Apologies if this has been posted before, but just wanted to share a problem I was having with my L3940 (~700 hours on it) and what I did to fix it. It took a while to figure out, so I'm hoping this saves someone else some time.
Symptoms: Whenever I would raise the front-end loader or the box-scrapper, the hydraulics would shudder noticeably. I also started having problems with the power steering that made it very difficult to steer. Both of the issues seemed to get somewhat better as the tractor warmed up, but still not right.
Fix: The fix was actually pretty simple. There is an inlet hose that I believe provides some kind of suction for the hydraulics. This hose had a very small crack in it on the backside that could not be seen from the front. The hose actually looked to be in good shape from the parts of it that I could see. I only found it by feeling the backside of the hose with my fingers. I was surprised how small the crack was, for causing such significant problems. The replacement part is Kubota part #TD170-33343. Cost for the part was $33 (plus I ordered 2 new pipe bands for another $10). It only took about 10 minutes to replace the hose, and the tractor was good as new. I suspect it got better as the tractor warmed up due to expansion of the hose from engine heat that caused the crack to somewhat seal itself.
7,157
Good to know. Thanks for posting. I'll copy this post and insert it in my WSM for future reference. And welcome to the forum!
kevinj
L3940hstc - B7500hst - BX1860 - Farmall 560D - Farmall M
Jun 4, 2018
101
Known problem, I had the same issue about 8 years back and my dealer has a bulletin about.
Has been fine since, now the trans input housing & and seals have been replaced. Another known issue that Kubota will not pay for.
200mph
Mar 3, 2017
1,228
65
PA
Thanks for posting your findings along with the photos to make it clear what part was the root cause.
kiroli44
West Monroe,la
Thanks so much for info-- i lost some sleep when my l3940 power steering stoped working--also pump making loud noise--then i saw your post --ordered exact part td170-3334 and replaced and tractor like new now--sleeping good now
00bushhog06
L3400DT/LA463, 3 bush hogs, 2 boxblades, tiller, 97 Ford F350 Dump, 18' trailer
Nov 26, 2019
9
OKATIE, SC
I had the same hose go out on my L3400DT. Got a pinhole in it and hydraulics quit working. Replaced the hose and heart attack avoided!
KubotaRog
Kubota L4240
Jul 4, 2024
Missouri
This post saved the day for me and my L4240! Was experiencing sluggish hydraulics which continued to worsen the past few months! I'd changed all the hydro filters and replaced the fluid with Kubota brand as recommended but problem still persisted! After reading this post I decided I didn't have much to lose ($45) cost of hose and as soon as I removed the old hose it was very evident it had major cracks on the back side! When I fired the L4240 up all the hydraulics worked like new! I couldn't be happier! Thanks to everyone who took the time to reply about this issue!!!
