L3901 starts fine but runs very rough and wont rev
matR
L3901
Aug 18, 2018
Cedar, Michigan
This problem just started on my 2016 L3901 (HST) that has very few hours (~120). It runs very rough, wont rev above 1200, and is producing a lot of black choking exhaust.
I assume this is a fuel problem? I checked the air filter, cleaned out fuel trap - no difference. Assume next step would be to replace fuel filter?
Any other things I should check?
thanks
9,089
Smell the fuel, smell like gasoline?
If it's not a fuel contamination issue, it's a fuel delivery issue.
I would say you have a failed injector.
Not something you can work on on your own, your going to need to take it to a dealer to get it fixed.
Don't run it like it is, as you will seriously damage the emissions equipment, if that hasn't happened already!
