L3901 PO606 CODE
Newbe
L3901
Dec 2, 2015
GOFF. N.H.
Greetings,
Happy new year!
After searching I still can't find a way to get the code to clear. I disconnected the battery to no avail. The battery went low after leaving flashers on and before I used my charger to get it running the code appeared.
Does anyone know how to clear this or is a trip to the dealer in order?
Thanks in advance.
Tom
sheepfarmer
Nov 14, 2014
4,438
677
MidMichigan
In this thread is the procedure for the owner to try to clear the code themselves. I don’t have access to the directions for an L01, my computer is down, and theL60s have different panels, but if you are able to follow what he has written it may save you a trip. Post #9.
5,504
2,213
P0606 will pop up if the ecu senses lower than expected voltage for x amount of time. Happens often in the winter when battery voltages drop because of cold. Clear it and see if it comes back. Probably not but keep an eye on it anyway. P0606 will be stored in the ecu but it doesn't necessarily come back in the panel after cleared, so long as the voltage threshold isn't exceeded.
