l39 warning light
arcticzl
caledonia ny
i have a orange warning light that came on its on the insterment cluster to the right.tractor wont start it just clicks a relay. its a picture of a tractor with a round circle under the tractor and a arrow going around the circle.any idea what this is?
10,357
PTO is engaged, you need to disengage it for the tractor to start. ;)
4,895
Sometimes the safety switch will not make up so set it and release it a couple of times. Let it snap back, or maybe try holding it up as in the released position. Sometimes the linkage is just a tad out of adjustment.
arcticzl
caledonia ny
It's the light pictured above.the PTO light which is not on has a similar picture but has it on the pto shaft at the rear of the tractor
arcticzl
caledonia ny
I don't know anything about an L39 but does it have a mid PTO? Even if it does not according to the link http://tractorpoint.com/forum/kubota-tractor-review/194222/1/Phantom-mid-PTO-signal-shuts-off-engine-and-keeps-it-from-starting.html it probably still has the harness for it.
It doesn't have a mid pto but thanks.i see I'm not in the same boat.. First thing I'm going to try is seat safety switch.it probably doesn't have anything to do with the Mid pto light coming on but the tractor quite when I was turning the seat around or maybe when I stood up to turn the seat.i will keep you posted thanks
5,506
2,215
For some reason the tractor "thinks" the mid pto is on. Need to find out why. Relay, wiring, etc? There's probably a wire underneath the tractor that's broken, shorted, open, etc.
