L3800, electrical advise needed!
Ok, I'm pretty ignorant when it comes to most matters electrical. So I need your responses to be in simple terms for a simple guy.
I just picked up a small atv broadcast seeded, that I would like to modify to fit on my tractor. It has a 12VDC electric motor which used to be hooked directly to the atv's battery. There is an open electric plug under the left fender on the L3800, see pic.
Ideally, I would like to replace the wiring, put an on/off switch that's easy to reach from the seat and a connector to plug into the open plug under the fender.
Will this work?
How do I test how many amps that plug is receiving? I do have a multimeter but its a little Greek to me.
Thanks for the help.
Ben
Will this work?
Ben
