Hello, I'm new to the Forum. I own a l 3600 with a GST shift transmission. I recently had one side of the cable for the GST shifter break so I've replaced it with a new one. After installing it I noticed it wouldn't go into gear until I move the shifter all the way down to 3rd gear position. so I assumed it was an adjustment issue and went back down to the dealer to get the adjustment procedure. I have adjusted this thing back and forth for an hour with no progress. At times it won't move it all. For the most part I have 3 gears starting from the third gear position slow, medium at 7th position and fast at 8th. There is no progression in between these three positions anymore. I can see the oil level in the sight glass and it looks clean as it did the day I got it. the machine has a little over 400 hours on it. I'm assuming I'm having a problem with the valve body or shift valve assembly? I am a transmission mechanic and I'm not afraid to jump in here. Has anybody experienced this before or have any legitimate advice on how to start diagnosis of this problem?
