L355SS stops moving
David-in-OK
L355SS, brush hog, box blade
Aug 2, 2020
58
Oklahoma
I have an old LS355SS and today when I hooked up the Brush Hog, I was mowing for 5 or so minutes and it just stopped going forward, like it shifted into neutral. I lifted the Brush Hog and it moved again. Then it wouldn't go forward, but did in reverse with the brush hog raised, I was able to get to the barn. I engaged the pto and heard a load clang. its full of fluid as i added ma few gallons. Trying to figure out what it could be/where to look.
BigG
Sep 14, 2018
1,953
774
West Central,FL
David-in-OK
Aug 2, 2020
58
Oklahoma
Makes sense to me, it fits what lead up to the problem. I cant seem to find the flow priority valve you have shown. Here's what I have, Included model and serial number cause Im not sure what year it is.
IMG_20200803_171918918.jpg IMG_20200803_171945473.jpg IMG_20190629_080145517.jpg
10,382
It's in your second picture with the single line running forward.
David-in-OK
Aug 2, 2020
58
Oklahoma
Well that seemed to due the trick. When I pulled the top plug, it kinda had a rusty sediment on it. I didn't have a drill big enough to chuck up the plunger, so I just polished by hand the best I could. After installing, I was able to due everything, but had a few spots of slight hesitation moving forward. So, I'm pretty sure if I pulled it back out and took a couple thou off it it would work perfectly as it was slightly tight when I re-installed the plunger. Thanks for the advice.
David-in-OK
Aug 2, 2020
58
Oklahoma
Well, it worked for a bit. Now the same problem. Seems to move fine in reverse. If I go forward, it makes it about 20 ft. I shuttle shift into reverse and it goes, then back to forward and it moves again. I have the brush hog lifted with the 3 point and a lifting cylinder it slowly lowers with the lifting cylinder m(that leaks like a sieve) The flow control plunger moves freely, I cleaned it up. Any Ideas?
to reverse and it moves fine
10,382
It could be simple as a piston seal replacement, but the labor to get to it is not simple.
I wish you luck in it only needing seals as the hydraulic clutch pack is not easy or cheap to find for these!
