Just bought a L355ss.
1800 Hours ????
Forward shuttle slips in higher gears meaning no go. Reverse works fine.
This tractor has loader.
Seems to get worse when warmer
Checked the Shuttle mechanism up to shuttle valve control and no problems.
There is a knob for warm or cold weather. I have not tried to see if it makes a difference.
How likely is that the clutch pack has worn out versus the clutch piston leaking?
Where do I check the forward and reverse pressure.
Thank you,
Later J
1800 Hours ????
Thank you,
Later J
