L355 forward shuttle no go
joeblack5
L355SS
Dec 18, 2014
State College PA
Just bought a L355ss.
1800 Hours ????
Forward shuttle slips in higher gears meaning no go. Reverse works fine.
This tractor has loader.
Seems to get worse when warmer
Checked the Shuttle mechanism up to shuttle valve control and no problems.
There is a knob for warm or cold weather. I have not tried to see if it makes a difference.
How likely is that the clutch pack has worn out versus the clutch piston leaking?
Where do I check the forward and reverse pressure.
Thank you,
Later J
9,200
I'll PM you a link to the WSM for download, and on page 45 it has the pressures and testing procedure. ;)
heppeone
L3750dt w/fel, woods box blade, woods rake, woods yard roller
Oct 24, 2014
22
murrells inlet, sc
Did you ever find out the problem? I’ve got a L3750dt with same issue, had to get work done like this, running around in reverse can get tricky with forks on the FEL bucket and bush hog on the rear. Thanks
9,200
No where near the same system on your L3750 as a L355.
