L3430 hydraulics
dustyandval
L3430-GST, LA723 Loader
Aug 23, 2010
Milton, Florida
I have a 2003 L3430 GST with FEL & I just bought a subframe mounted backhoe for. I don't have any open ports to attach the backhoe hydraulics to. What parts will i need to get this thing going? Is there a flow divider kit or something? Thanks - Hunter
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,418
34
Rocky Face, Georgia
My backhoe is self contained and is driven by a pto pump. This is the second Kubota backhoe that had this type of set up. Does yours have a hyd tank?
dustyandval
Aug 23, 2010
Milton, Florida
I have done some research & learned that my backhoe is powered by the power beyond hydraulic hose that runs from the loader valve to the port below the right floor board. There is not tank or pump on the hoe. It should be an easy hook up. Thanks
MDCobraMan
Kubota L3430 Grand Open ROPS, L3430 Grand Cab, F2400
Jun 8, 2021
25
12
I'm also trying to get some exact details to add the hyd lines to and from a backhoe I added to my L3430. I see the P port but can I simply Tee into this and if so where should I run the return line?
