L3301HST Power steering
animals45
L3301l
Apr 22, 2021
282
Mabie CA
My power steering started feelin like it wasn't workin yesterday . if I gave it a bit more throttle it started feeling better . It hasn't done that in the past . I went all through the FSM & owners man & I can't find anywhere a power steering pump or reservoir
anywhere . I can find mention of a steering hose but thats it . Does this tractor have a separate pimp & reservoir
or does it use the tractors hydraulics for power steering ?
thanks
animal
5,289
thanks
animal
The main hydraulic pump on the L3301 is a tandem pump. One section is used for tractor hydraulics and the other section for power steering. They share a common supply line. The WSM explains it on great detail
animals45
L3301l
Apr 22, 2021
282
Mabie CA
Hydraulic fluid is fine . I need to go through my box & see my any of my pressure gages go hi enough to do the pressure test .
thanks
animals45
8,766
Very unlikely to be a pressure issue, it's more likely a seal issue or a controller issue.
Explain in great detail what happens and when it happens.
BAP
Dec 31, 2012
2,937
1,049
What were you doing at the time with it? Did you have a fully loaded bucket? Are the tires inflated properly? A heavy bucket load will require more to make the steering feel like it’s working the same.
retired farmer
tractor, loader, cutter, blade
May 25, 2020
188
107
sheridan
My L3301 has very weak power steering until I press the HST pedal or at the least a little movement of the tractor. I have read somewhere that, that is normal.
rr
animals45
L3301l
Apr 22, 2021
282
Mabie CA
Bucket was empty . I was pulling into my shop to lift my lathe & I couldn't turn the wheel to make the turn . I tried backing up & turning & still nothing , I would try to turn the steering wheel & it would turn maybe 5 degrees which is the play in the system & then it would feel like I had hit something . I gave it a bit more throttle then everything was fine . My wife drove it home afterwards @ 1 1/5 miles & no problems . On my old Case 580's they would act the same way if they were low on steering fluid . I'll order up a pair of transmission & hydraulic filters & change them .
thanks
animal
