Here are some pics of my installation of rear remotes and cylinders for T'nT on my 3301. I had installed a Long 3rd function valve previously and had wanted to additionally add the rear remotes. I hope this may help someone as I had been helped here before.
The valve assembly is a Prince Wolverine MB series. This is a smaller double spool valve which fits nicely on the inside fender of the tractor. The top link cylinder is from Surplus Center and the side link is from aftermarket.com. I had to bend the lower tangs on the side link, and drill the holes a bit larger for everything to line up properly. Also installed a needle valve on the side link to slow things down a bit. All parts including hoses, fittings, etc. came to about $950 including freight and tax.
