L3301 Fuel Guage
BSchneiderbauer
L3301, loader, grapple, Pallet fork attachment, Titian Flail mower, ballast box
Nov 15, 2025
14
Townsend Ma
I filled up the tractor before doing a day of work. The guage is now showing full with only a half tank. I filled it, and will monitor. It looks like there is a vacuum line that come out of the top of the tank and leads to a wiring harness. Any ideas??
BX23-S,57 A-C D-14,
6,277
had a look online parts, 'normal' fuel sensor mounted on plastic tank... I suspect a crummy ground from the sensor to chassis . The 'should' be a black wire attached to one of the 6 screws securing the sender to the tank.
Ridger
L3940 HST
Nov 26, 2014
164
19
North LA
As stated above, it may not be getting a good ground. I was having the same problem and added a ground wire and now it works as it should.
