L3240 Leak -
Pquackenbush86
L3010, 5 Ft. Bush Hog, 6 Ft. Finish Mower
Jan 19, 2011
27
Mooresville, NC
So I made a post about 2 months ago asking for advice on how much I should pay the dealer for a second attempt at repairing the leak from my bellhousing. So far I have spent $2400 and yesterday used it for the first time since getting it back and it's still leaking. It's leaking hst fluid from the bellhousing drain valve in a drip drip drip. I'm a mechanic by trade and the only reason I took it to Kubota was I figured when I sell it I wanted to be able to show receipts for the repairs. I called my dealer and they don't have any idea what could be leaking. Any ideas? Should I try another dealer?
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,255
1,059
Williamstown Ontario Canada
What does your bill say in the way of describing the problem you took it to them for?
If it says "leak and bell housing," and in 60 days it is leaking again I would be yelling very loud.
Since getting the tractor back 2 months ago, what have you used it for, you indicated you have not used it but did you when you first got it back? Have you added any fluid?
Does it leak when stopped over night?
Dave M7040
Pquackenbush86
Jan 19, 2011
27
Mooresville, NC
So will the existing dealer not stand behind their work ?
Yes they told me to bring it back up there, the issue is they don't sound very confident in their guess as to what could be leaking. I already lost the entire summer of work because they have had it since beginning of June.
Pquackenbush86
Jan 19, 2011
27
Mooresville, NC
Dave M7040
I got it back about 2 weeks ago and this was the first chance I had to use it. 2wd sitting still using the backhoe started dripping
rentthis
1,010
25
summerville,sc
I have a 3240 that did the same thing. A bad seal inside the transmission case was leaking. My dealer talked to Kubota and it was a known issue. It was repaired under warranty.
