L3200 light upgrade
Fordtech86
L3200
Aug 7, 2018
4,794
5,628
Pineville,LA
Well as the days get shorter the work never ends,finally got around to starting my light upgrade.Today was mounting and fitting the lights and making a switch box.L Series ain’t too accommodating for add ons in the dash area
bambam31
L3800HST 4x4,R1,FEL, 6'disc, 5'bush hog,piranhaTB,6'grader,6'rake, 48"forks
Apr 3, 2014
315
26
23
Mobile, AL
It feels good to get a project like that finished up. I purchased the same lights and did nothing with them for over a year. I recently got mine rigged up on the ROPS. Now I want to install a rear view mirror under my canopy.
Fordtech86
L3200
Aug 7, 2018
4,794
5,628
Pineville,LA
I bought the small lights over a year ago along with a light bar to my zero turn.put the bar on the zero turn back then,order another bar for the tractor,should have it all wired up tomorrow
Fordtech86
L3200
Aug 7, 2018
4,794
5,628
Pineville,LA
I used the existing holes in the ROPS to mount the lights,my ROPS is down 99% of the time,only up now for the project
Fordtech86
L3200
Aug 7, 2018
4,794
5,628
Pineville,LA
Had to make the bracket for the rear lights and make the box for the switches,I ordered the switch panel with the three switches,the volt meter and a dual usb outlet,panel didn’t end up working,got a 4x4x4 pvc box at lowes and cut it out for the switches,really had no use for the usb,the push button switch will be for my sprayer
Fordtech86
L3200
Aug 7, 2018
4,794
5,628
Pineville,LA
Finished all the wiring today,know I should have drilled into the ROPS,but I can’t see a few 1/4 inch holes really hurting it,makes a much cleaner install.
Fordtech86
L3200
Aug 7, 2018
4,794
5,628
Pineville,LA
And as luck would have it...
But on the plus side,measured the 20 inch bar that I put on my zero turn,it will fit just inside the bumper.Got one coming
Fordtech86
L3200
Aug 7, 2018
4,794
5,628
Pineville,LA
Got the new bar in a couple days ago,finally got around to putting it on
Fordtech86
L3200
Aug 7, 2018
4,794
5,628
Pineville,LA
Just the bar
Bar and roll bar lights
And out the back
Fordtech86
L3200
Aug 7, 2018
4,794
5,628
Pineville,LA
I like your rear light bar set up,I got a replacement 17 inch bar for the first one I put on the front that didn’t work, thinking about mounting it on the back to replace the two small lights
Fordtech86
L3200
Aug 7, 2018
4,794
5,628
Pineville,LA
Reviving this as my set up has changed since this original post (and seems like parts of this thread was lost in the site crossover).
Had to do away with the rear lights after I added the backhoe because the fender support they are mounted to is removed to clear the back hoe seat. Not sure yet if I will keep the 2 small lights for the rear or swap out for the light bar I got laying around.
I also needed to finish the wiring for my sprayer. The project box I have for the switches, fuses, and relays had no more room left to add the sprayer circuit. So time to re think all this.
Got an auxiliary fuse/relay panel to help with this. Had planned on putting it under the dash panel but there wasn’t enough room.
Ended up mounting it to the back of the fender (don’t mind the wiring mess yet)
It comes as a bare box with bags of teminal ends.
Getting the box wired up if very tedious.
Will hopefully finish it up tomorrow.
(Dont mind the dirty tractor 😂 Couldnt get it washed before I started
Fordtech86
L3200
Aug 7, 2018
4,794
5,628
Pineville,LA
Got it all finished up today.
Box and wiring ran.
kept the switch box. The round switch is for the sprayer.
Plug for the sprayer
Fordtech86
L3200
Aug 7, 2018
4,794
5,628
Pineville,LA
stayed with the small cubes on the rear, yes I drilled the rops, don’t care.
front bar and forward cubes on the rops stayed the same
Fordtech86
L3200
Aug 7, 2018
4,794
5,628
Pineville,LA
Who makes that relay/fuse box? That looks like a slick way to add high load circuits.
12V Auto Waterproof Fuse Relay Box Block Kit [6 Bosch Style Relay Holder] [6 ATC/ATO Fuse Holder] [Relays & Fuses Included] Universal Relay Block Box for 12V Automotive Vehicles Cars Marine Boat Jeep https://www.amazon.com/dp/B08KHVHLL...abc_A77NDDSTFANK6Q6ZBF9D?_encoding=UTF8&psc=1
Here’s a link to the one I got. It is a bare box, it comes with the terminal ends that go in the box but you have to supply the wiring.
