L2900 temperature gauge inop
peanuts
L2900 GST
Feb 18, 2015
Bedias
My temperature gauge stopped working; stays pegged low. I checked the wiring visually, replaced the sender and the gauge. Still inop. Ideas?
5,124
Meter the gauge one side should be hot with key on, other is sending unit, ground that side and gauge should climb to top, if that works bad wire from gauge to sending unit.
mickeyd
Mar 21, 2014
1,192
17
38
Guin, AL
Welcome to the forum Peanuts.
peanuts
L2900 GST
Feb 18, 2015
Bedias
Thanks for the good advice. I should have done that first and I would not have replaced the gauge. But, I can short the terminals that plug onto the sender, and the gauge responds by climbing normally. I guess I have a bad new sender. Doesn't sound right, but I don't see any other explanation.
4,544
Does one of the wires going to the sending unit go to a ground?
Could be just a bad/ loose connection at the plug where it ties to the sending unit? Try wiggling the wires at the sending unit first while someone watches the gauge. If the gauge jumps intermittently then it's just a connection in the wiring
peanuts
L2900 GST
Feb 18, 2015
Bedias
Yes, one side of the plug goes to ground and the other to the gauge. When a jumper is used between the plug ends, the gauge is then grounded and responds by climbing to hot. I've made sure the plug terminals connect to the sender terminals by "closing" the plug terminals slightly so it is a snug fit. Still nothing out of the sender. Anybody know what the ohms reading should be when the sender is hot. Logic would say it should approach zero when the water in near boiling.
peanuts
L2900 GST
Feb 18, 2015
Bedias
I noticed that the voltage at the gauge is only 4.3 but the board has 7v printed on it. What is the source of the 7 volts? In the parts lists I don't see a transformer.
peanuts
L2900 GST
Feb 18, 2015
Bedias
Its been a while since I was on the forum so I thought I would report what the issue was with the L2900 temp gauge. The L2900 has two temp sensors, one near the thermostat and the other at the aft end of the head. It turned out that the wire from the front sensor was OK but the wire from the aft sensor was broken. Caused the gauge to barely register. Repaired wire to the aft sensor and now the gauge works fine.
