The Draft Control linkage to the valve is broken off which got me to taking a closer look. Don't know how or why it would be broken. I can move the top link plate at the linkage connection about 1/16" of an inch. I don't know how sensitive the Draft Control Valve is, but would this "slop" affect the draft control function? If so, did someone break the linage off to disable the draft control?
I found the 1/16" "slop" is at the Torsion Bar pin. I may be wrong, but I am assuming it's a tapered pin. Additionally, the pins have been welded in place.
Questions--
1. Should I be concerned about the 1/16" "slop"?
2. Are the pins tapered?
3. Are the pins welding in place at the factory or is this a "farmer" fix?
Questions--
