mikeboggess New member Equipment L2800 Sep 27, 2017 29 3 3 Canton May 4, 2026 #1 Will someone help me determine the placement of the 7 12 mm bolts go on this tractor. Primarily concerned about the long bolts as there are two different lengths of the long bolts.
B Bee-Positive Well-known member Equipment BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box Nov 16, 2022 845 828 93 Amsterdam, NY May 4, 2026 #2 You should have three longer bolts (#080 in diagram) with eight shorter bolts (#100 in diagram) and two studs (part #090 & 110 in diagram). To see the bolt lengths click on each bolt on the right parts list at Messick's
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 35,600 10,706 113 Sandpoint, ID May 4, 2026 #3 The thicker the case the longer the bolt, the thinner the case the shorter the bolt. Your 7 count should be 8.
