I have 30 yrs old L275 with 1800 hrs and NEVER had any work done to it. Front end loader AND 3 point lift very, very slow and weak ONLY when fluid is hot. Changed transmission fluid and filter approx 50 hrs ago and fluid level is fine. No screens on this model. No air in lines. No power steering and I cant find any of the lines that are leaking and could be sucking air.
Makes sense to me that the pump is worn because hydraulics work fine when cold but not once it gets hot and I assume that is because the fluid is thinner . But; I am not a mechanic. NONE of the loader or 3pt lift cylinders are leaking. Before I buy/replace the hydraulic pump. Any other ideas??
Thanks
Thanks
