L275 and l3800 wheel sizes
Rotndog
L275
Dec 31, 2016
Washington
I found a set of tires and wheels that might fit my l275dt. The ad says they were on a l3800. Before I drive three hours to get them, does anyone know if the wheels share the same bolt pattern? The rear tires are 11.2-24 and the fronts are 7.2-16. My rear tires are the same but the front are 7-16. Will the difference between 7 and 7.2 damage the 4x4?
Thanks for the help.
tiredguy
B3030 HSTC,B2781 51" front mounted snowblower,60" MMM
Jan 21, 2010
301
northern lower Michigan
Rotndog,
the wheels on the L series have a different bolt pattern and offset so no the
will not fit. The tires will fit on your wheels perfectly and the only difference
between a 7-16 and 7.2-16 is 2/10ths of an inch in width which will not bother
a single thing. If memory serves me correctly on Goodyear and Titan made the
7.2 width tire everyone else marked theirs 7.
Weigh the price of the L series take offs versus new and the cost of swapping
them on the rims if you can't do that yourself to know whether the savings is
worth buying them.
Al
Rotndog
L275
Dec 31, 2016
Washington
Thank you Tiredguy. I did make the drive this morning to look at them before I saw your reply. I brought a front wheel and the rear center off my tractor for comparison. The back will work but the front is different. I did ok on the price so I will change the tires to my wheels. The tires still had the little nubs on them.
