L275 4x4 power steering
ecphsca
nepa
I recently purchased a L275 4x4 with fel. Was told the power steering seal was leaking. PS seemed to work fine. Turns out the sector shaft was welded (terrible hack job) and looks like the steering box is beyond repair now. Apparently 4x4 PS boxes are very scarce and new ones are no longer available. Tractor otherwise is in great condition. Would install a manual box but I'm worried about hard steering with a loaded front bucker. Any idea on where to source a usable steering box?
Thanks,
Joe
XXXXjandlracing91@XXXXhotXXXXmail.XXXXcom (remove all X's and use no spaces to contact)
Moderator note: Please do not put direct contact info in post. Attracts bots.
rbargeron
Jul 6, 2015
1,183
260
western ma
The power assist offered by the original style steering box isn't very strong so you might not find a new aftermarket manual box that much harder to steer.
coachgeo
Nov 16, 2012
2,459
37
Southern OH
If you've not done so already there is a few threads in here on power steering you might can get some ideas from. If recall right most were about tractors in the era of the L275
Maybe start with a search for ( "power steering" L275 )
Otherwise mount a manual box. Easier to find.
A 4x4 fabrication shop that builds/repairs rock crawlers (or a talented backyard hack) could probably build you a power assist set up with an orbital? valve and a cylinder. An Ag/Tractor shop may can do the same.
