Tractor is fairly new to me, first winter with it and temps have been 12-30 degrees F for the last 10 days.....
Kubota L2650, Shuttle Shift, 4x4. 2500 Hours.
factory front end loader, has prompt response and full range lift and curl
tiller on the 3 point hitch, prompt response, goes up and down great
Hydraulic oil in sight bubble seems to be a little full... maybe a little above the 3/4 mark.... (I think the fluid may be some of whatever was in there when I got it and some tractor supply premium fluid)
Now, the tractor will go forward and backward in low range gear 1 but gear 2, 3 or 4 the tractor becomes labored and is obviously not proper.
High range we dont move at all in any gear. I have let it warm up for 20 minutes and moved all my shifter leavers, high low range, 4 wheel drive selector...
I wonder if this fluid is the problem? I am scared that I have a more serious problem. I had a FEL lift cylinder go out in early November and my fluid got low and the tractor would not move. I fixed the cylinder and topped the fluid off and everything seemed great until this week.
Any ideas are welcomed, also following other similar threads,
thanks
thanks
