Now that it's getting cold out I need to get no glow plugs working. I was able to start it ok in the summer without them, but obviously not now. Anyhow, I think I narrowed it down to the ignition switch. When I turn it counterclockwise to activate then nothing happens. I cheers l checked continuity on the terminals for them & there isn't any so I'm guessing the switch is bad. The weird thing is there's an extra button in the circuit that I don't think belongs. Attached is a pic of it. Seems like it's have to press it when trying to glow. Is this correct or is it supposed to be an indicator and someone put a button there instead?
Also, how do I get the switch out? There's a brass nut looking ring under the lever but it's completely round with little holes at 12 and 6. I thought there we're set screws in them but I couldn't find them. Turning it only turns the whole thing. Should I just put penetrating oil on it to loosen it up or am I missing something?
Thanks!
Mike
Sent from my SM-N960U using Tapatalk
Thanks!
Mike
