L260 Battery size/group?
McRoth
L260
May 22, 2018
32
Grafton, Ohio
I'm needing to replace the battery in my L260 & want to get one that fits the long, skinny tray. Searching online I'm finding 30H or 24F. The stock # is 32260-33202, but I couldn't cross that to the spec number.
Anyone know for sure?
Thanks!
Sent from my Pixel XL using Tapatalk
6,643
You could measure the area the battery needs to fit. Take the H-L-W and give that to the auto part folks. They should tell you what they have that fits. Then if you have a choice buy the one with the most CCA.
Be sure the post are in the correct position side to side. The battery will have a group number and if there is an "R"a after the number it's a "reverse" post position.
I just bought a battery for a B7100. Size was 5" wide, 9 3/8" long, 8 3/4" wide. Turns out a group 51 fits right in. 500CCA, 615CA. Interstate was $10 cheaper than Wal-mart!!!
2,835
I just did the same thing this past week......
B7100 - needed the 51R, and got it at wally world, hurt my feelings at the counter too! about $120 out the door, old one was shot.:D
McRoth
L260
May 22, 2018
32
Grafton, Ohio
The old battery worked for a while longer after I adjusted the valves. I just got one and a H9 fit perfectly. Group 95R.
Sent from my SM-N960U using Tapatalk
