My L2501 is really bogging down when under a load. Shakes, skips, etc.. Has all the classic symptoms described in this forum as water/algae in fuel or clogging lines. The tractor is 2017 model and has 52 hours service. I started to notice this “bogging” issue around 47 hours. It would just be a quick skip in the engine and then be fine for another hour or so. But it got progressively worse.
I knew it was almost time for me to perform the 50 hour maintenance and thought installing a new fuel and air filter would solve the skipping problem. It did not. Still the exact same problem. I did not drain the tank fuel when I did service. I didn’t note any trash or water inside the fuel bowl. I did add 5 gallons of fresh (off-road) fuel and treated the 5 gallons with this Star-Tron additive per the additive manufacturers recommended ratio. That’s the only treated fuel I’ve ever ran through this machine. Yes I know—shame on me. Pretty sure this problem is all my fault. But in my defense, I’ve never owned anything with a diesel engine. I also didn’t know that a tractor needs to go through winter with a full tank of fuel. With treatment added. My tractor also sits outside. So everything you could do wrong related to fuel, I did it for 2.5 years. Now payday is here. I’m still learning and maybe people will read and learn as I have. Now a couple questions about fixing this whole debacle………
I plan to totally drain the tank and dispose of my ¾ tank of fuel. Not taking any chances. I suppose that’s the best action to start with? My simple mind breaks the fuel system into 2 halves; fuel tank-side of the bowl and engine-side of the bowl.
• I just remove the fuel line from the bottom of the tank, clean the inside of the tank, blow out the line with compressed air?
• Do I need to do anything initially on the engine-side of the fuel bowl?
• I suppose I need to install another new fuel filter.
• What is the favorite fuel additive of the experts here? What’s the best product to add to the first tank of new fuel that will help blow the gunk out of the lines, injectors, etc.? What ratio per 5 gallons? From reading here, sounds like most folks use way more than manufacturers recommended ratios. Also, our winter temps seldom get below 20 degrees around these parts so I’m not concerned about fuel gelling and such.
• Any concerns about getting the fuel system primed back up? I’m thinking it’s just let the bowl get filled similar to when I changed the filter?
Any advice would be appreciated.
