L245dt Did a twist & through me out of the seat
bobelee31
L245DT
May 22, 2013
9
Troy, IL, USA
I had trouble several times with tractor right rear wheel raising up . like it was going to turn over while moving . anyone else have this type experience.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
I assume you were on a bank or slope of some sort. If so then yes, happens alot while working on banks.
bobelee31
L245DT
May 22, 2013
9
Troy, IL, USA
1st time it happened I was baking straight out of a dig area over a 6" or 8" hump in 4 wheel drive. It threw me out of the seat.
Bulldog
Mar 30, 2010
5,434
76
Rocky Face, Georgia
Sounds like you either didn't have any ballast or didn't have enough ballast on the rearend. Bad things can happen quick.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
Richmond Va
If you are going to fast with ground speed yeah it can toss ya. I was plowing the street in front of my house with the tractor and a scrape blade. Clipping along at a pretty good pase I snaged a man hole that was an inch above street level and ended up kissing the hood of the tractor.
gpreuss
Oct 9, 2011
1,166
Spokane, WA
The front axle can swivel quite a bit on that 245. With enough weight in the front, you can get a sort of stable plane with the two front and one rear tire - problem is it goes there in a hurry!
If I remember correctly, the FEL on that tractor is good for 600-800 lbs. So you need that much weight out behind you to keep things stable! I always had at least a rear blade - about 350 lbs - mounted if I was going to do any picking up or digging.
Go slow as well.
bobelee31
L245DT
May 22, 2013
9
Troy, IL, USA
First I would like to thank Bulldog, Eric McCarthy & gpreuss for there quick replys. I will be looking for some rear ballast.
Thanks Again: Bob Converse
Bulldog
Mar 30, 2010
5,434
76
Rocky Face, Georgia
I make it a point to never do loader work without something hanging on the 3pt. My rear tires are loaded but to me that's just extra insurance, I still want counterweight in addition to loaded tires.
Be safe and happy tractoring. :cool:
Bluegill
Jan 11, 2012
1,559
Success Missouri
I wont even use the tractor with FEL on unless I have rear ballast on the 3 pt hitch. The loader alone is Too much weight on the front end for me...
BadDog
B7100D TL and B2150D TLB
Jun 5, 2013
579
Phoenix, AZ
Thanks again looks like I am in the market for a rear ballast.
A box gannon/scraper works well, as does a heavy grader blade, or anything else you have that is fairly heavy to hang off back there, or even something you can stack weight on (like a gannon). I don't see much point in a specific ballast box, unless you just need weight and don't have anything suitable, need to keep the interference zone to a minimum (turns, etc), or you somehow need to "tune" the weight.
Bluegill
Jan 11, 2012
1,559
Success Missouri
A dedicated ballast is nice because they are usually small and don't hang out too far and get in the way. But I usually use a box blade with weight added, because I usually need the box blade anyway when using the FEL.
bcbull378
GL3830,fel,brush hog,pallet forks,disc,gannon,auger,springtooth,plow,drag,ripper
Sep 6, 2011
579
32
Ventura Ca
any time Im going to be using FEL I have something on the 3pt hitch and " always wear your seat belt" your better off in the seat especially in a roll over
