L245 Lower Hose???
Kevin 70068
L245
Aug 9, 2023
Laplace, Louisiana
Hi guys, I just bought a L245 tractor and noticed the hoses were in bad shape. Decided to replace them. New one came in and seems to be molded a little different. Is this the correct hose? Also noticed that old hose had damage where the belt has been hitting it. Any advice or help would be appreciated.
10,381
Yes that's the right lower hose for a L245.
More pictures of the radiator, as it's possible that someone has changed it, as it looks like the lower outlet doesn't come off at an angle like it should.
Kevin 70068
L245
Aug 9, 2023
Laplace, Louisiana
Yes it has been changed. I’ll take better pictures tonight. The lower outlet is straight definitely not on an angle. Thing he put the wrong one on?
10,381
Yes looks like the wrong radiator.
10,381
Other option is to use a copper fitting to turn it the right way.
Just a short piece of hose with a 45 degree or a 22.5 degree elbow will probably do it.
Or a local radiator shop can fix it.
